Hi All
Can anyone share the steps to add a custom Mashup as an app to LandingPage in PTC Navigate?
Do we need to have the App Development Kit installed for this? Is it possible to add the mashup to the existing apps, like 'View Document'.
Mahesh
Hello, Mahesh Yalavarthi.
Let me first ask; are you using Navigate 1.5? I have been told by the Navigate team this is when extensive customization is supported. If that's the case, I'll check further with the Navigate team and find appropriate help for you.
Thank you,
-- Craig A.
Hi Craig
We are using version 1.4.1.
Mahesh
Mahesh Yalavarthi Were you able to find what you are looking for?
You may want to check out the Expert Sessions for ThingWorx Navigate at this location:
https://support.ptc.com/appserver/cs/portal/thingworx/csm.jsp?p=2
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
