How to use ThingView/Creoview Widget to display CAD Model in custom mashup in Thingworx Navigate 1.8
SOLVED
Highlighted
Aquamarine
I want to display 3D model in Creoview or Thingview, but as I bind 3D model to that widgets it's shows nothing.
please find attached img for linking ref.
Swapnil More
1 ACCEPTED SOLUTION
Re: How to use ThingView/Creoview Widget to display CAD Model in custom mashup in Thingworx Navigate
3 REPLIES 3
Hi @Swapnil_More ,
so as shown in you picture you tried to display the model in 2 different views: Creo view and thingview.
For creo View - if you try to  display you mashup in chrome - it will definitely not work. It work only on windows explorer where activeX are allowed. So that I do not think, that this is a real opton for usage.
So the second view thingview should work for pvz models.
Here example (in pictures):
Here example for sequence and selection on element tree (requires boom see Tech Tip on AR Studio community):
Also animations are working too.
Because it is not trivial to get this working ,  and could not be explained with few words , so I will not mention further details  in this post.
I am plaining to write a tech tip soon in the AR Studio community - hope until end of the next week.
Thank you & awaiting for your valueable tech-tips.
Swapnil More
