ISSUE about a SSL Connection Configuration PATH
SOLVED
Hi
Trying to install Navigate 1.6.
When accessing ThingWorx with the configuration so far, request the user certificate to Windchill and proceed to LandingPageAccessAppMashup.
However, the design data can not be loaded.
I installed Windchill in a state where HTTPS configuration was not completed.
The guide says that Windchill's SSL (understood as HTTPS configuration) configuration is essential for Navigate installation.
Therefore, we configured Windchill as HTTPS with a self-signed certificate for resolution.
I then reset the ptc-windchill-intergraion-connector.
Previously, we set the base URL to http: // <hostID> / Windchill.
At that time, ValidateConnection returned success.
I changed it to https: // <hostID> / Windchill / sslClientAuth when I set it up newly.
We also added the ssl keystore path and password to ptc-winndchill-intergration-connector-proxy.
The path is <PTC_Windchill> / java / lib / security / cacerts.
However, ValidateConnetion returns a failure.
Even in this configuration, when ThingWorx accesses, Windchill asks for user credentials and goes to LandingPageAccessAppMashup.
Do you have any issues like me?
Or is there anything I can guess about why I'm experiencing this phenomenon?
Thank you.
Re: ISSUE about a SSL Connection Configuration PATH
Since the last reply, we have created additional support articles CS288050 and CS288818 that should help with configuring Windchill Authentication and creatin the keystores/truststores.
Hi
The keystore should contain the Thingworx keys, not the Windchill keys, and it should be located on the Thingworx server. It is usually named thingworx.jks to help keep them straight. The Truststore should contain only the Windchill certificate, and is usually named windchill.jks. Instructions for creating these are found in Article CS247505, and I have a separate Word document that explains just the keystores (attached). The third party tool KeyStore Explorer has been helpful with creating and exporting various keystore related things.
Bob Arko
Navigate Technical Support Engineer
Hi @CHASEONHO
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
