I have "java 1.8.0_102" installed on my Redhat Enterprise Linux-7.6 system. I want to install TW Navigate 1.9.1 on same system. The version specified in System Requirement document is "java 1.8.0_92". But I have higher version install on my system, so can I continue to install navigate with higher version ? Or, I will have to install the exact specified version ? Also Windchill is also install on same system, so Java Home is set to Windchill java path, So I guess if I changed Java Home path to some other version , then will it affect windchill execution ?
Hi Mayur,
Ideally ThingWorx Navigate should work with later minor versions of Java as well(1.8.0_102 in this case). You can go ahead with the installation of ThingWorx Navigate with this java version
Tushar
Hi Mayur,
Tushar
