Hi I'm SeonHo
The current situation is that I installed the navigate extension and redirected it to navagate when I signed into Composer with Windchill's account
However, if you log in with your Windchill account, you will see "Unable to invoke service CollectApps on AppCollectionsConsolidator: You do not have permission to navigate apps.Please contact the Administrator".
However, as an Administrator's account (It changed the password to wcadmin after configuring the navigate.) I tried to modify AppCollectionConsolidator after logging in and it was not possible to fix it.(it was only view possible)
How do I view data through navigate with a Windchill account? How do I set it up?
thank
i solved this problem
i add wcadmin account into administrator group
thanks Sushant Pandey
Hi Seonho, would it be possible for you to open a support case for this?
