PTC Navigate 1.5 - no NavigateOrganization organization?
Participant
In the Navigate 1.5 doc there's mentioned NavigateOrganization organization which should help with setting the visibility. But as far as I can see, this organization is no longer in the PTC Navigate 1.5. Could anyone please confirm?
Tags (2)
3 REPLIES 3
Re: PTC Navigate 1.5 - no NavigateOrganization organization?
Hi Jakub,
I have used Navigate 1.5.1. We must create an Organization 'NavigateOrganization' and add all the non-Administrative user groups(Engineering, Quality, etc.) to that organization.
Highlighted
Yes, I created that, but this organization doesn't have set all the necessary visibility, you need to do that manually.
Yes, we have to add manually.
