PTC Navigate and SiteMinder
Regular Member
We got Navigate and SSL working, but when we turn on SSO tool Siteminder, we get the following error:
Wrapped javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target Cause: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Just wondering if anyone else is using Siteminder with Navigate. Many thanks in advance!
Tags (1)
Re: PTC Navigate and SiteMinder
i has similarly issue
Thingworx isn't config SSO
Windchill is config SSO
i can access to Thingworx using windchill account
but when i search windchill object that error's occur
occur same error when i execute a service that ValidateConnection
if you got solution, share me please
thanks
