PTC Navigate installation issue.
rmartinez
Hi,  I'm trying to install and configure PTC Navigate in Thingworx 7.1.
I follow every single steps and It works fine untill i try to import the "PTCNavigate_Example-1.3.0-04-imports.xml" file. It throws me the next error:
Error importing: error, Import Failed: Validation Failure: Thing CompositeEpmDocumentResourceProvider Had An Invalid Thing Template : [PTC.Resource.FlattenedCompositeResourceProviderTemplate]
Here is an image if you want to check it..
I would appreciate your help. Thank You.
9 REPLIES 9
Ronald, are you following an import sequence? It's missing a Template, most likely from another Entity import. Are there any other xml files remaining?
rmartinez
(To:Aanjan)
Hi, Aanjan, Thank you for your response.
Yes, I've followed every step on the installation guide, importing all files with success except  that one.
rmartinez
(To:Aanjan)
Did you import the 'TWX_Converge_Core_ExtensionPackage' extension already? It's part of the ThingWorx Utilities package.
rmartinez
(To:Aanjan)
Yes, I did. Actually, It was the first package i imported.
If so, do you have a template called "PTC.Resource.FlattenedCompositeResourceProviderTemplate"?
rmartinez
(To:Aanjan)
No, I don't have it.
Please try re-importing the 'TWX_Converge_Core_ExtensionPackage' as that seems to have the Thing Template you're missing.
rmartinez
(To:Aanjan)
I already did it. Like three times and did the same with the other packages.
