PTC Navigate
achaube
7-Bedrock
PTC Navigate
hello ,
I am trying to locally create a setup for configuring and using navigate with windchill,below are my version details which i have installed
Thingworx 7.1
Windchill 11 F000
Thingworx Utilities 7.1
BUt wheni go to download the below componenets
• Windchill Extension 1.5.0
• Navigate Framework 1.2.1
I am not getting them in the software download section of PTC support from where can i get the specfic versions of navigate framework and windchill extension.
Their are the latest version available can we use those instead or how to get the above version .
Kind Regards ,
Amar
1 ACCEPTED SOLUTION
hselarka
(To:achaube)
Hi Amol.
As mentioned, Navigate 1.3 which you are trying to install is not officially supported anymore and hence it has been removed from Support Site for download.
We would recommend you to download and install the latest supported version which is Navigate 1.6. Refer to ThingWorx Navigate Installation and Configuration Guide for more details of Navigate 1.6.
Thank you for your question; I am glad I was able to help you, would you please mark the answer as correct or provide a status update for the community?
BR,
Harsh Selarka
3 REPLIES 3
Hi Amar,
Navigate 1.3 which you are trying to install is not officially supported anymore and hence its removed from Support Site.
Let me know if this helps.
Tushar Bhosale
hselarka
(To:achaube)
Hi Amol.
BR,
Harsh Selarka
mnalla
7-Bedrock
(To:achaube)
Please see the compatibility matrix of thingWorx Navigate Support Matrix , I do not think Windchill extension 1.5.0 supports ThingWorx 7.1.0.  You may need to upgrade your thingworx version also
BR,
madhu
