SSO doesn't work with Pingfederate/Thingworx
Highlighted
Regular Member
I have some problems with configuring SSO. I did all steps on this document https://support.ptc.com/WCMS/files/172779/en/PTC_Single_Sign_on_Architecture_and_Configuration_Overv...  . I not sure about Scope, i did as on guide WINDCHIILL_READ. Is it right? At the moment i can login to thingworx trough sso but after I do changes in ptc-windchill-integration-connector and ptc-windchill-integration-connector-proxy i get this error
In Security log i found these errors:
2018-01-20 18:33:13.521+0300 [L: ERROR] [O: S.c.t.s.a.s.ThingworxSSOAuthenticator] [I: ] [U: ] [S: ] [T: https-jsse-nio-443-exec-4] [ Failed to utilize the SSO component for authentication ][ The requested scope(s) must be blank or a subset of the provided scopes. ]
2018-01-20 18:33:13.522+0300 [L: ERROR] [O: S.c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: https-jsse-nio-443-exec-4] Could not handle request
2018-01-20 18:33:13.524+0300 [L: ERROR] [O: S.c.t.s.a.AuthenticatorExceptionHandler] [I: ] [U: ] [S: ] [T: https-jsse-nio-443-exec-4] errorMessage: [Unauthorized], statusCode: [401]
2018-01-20 18:33:13.524+0300 [L: ERROR] [O: S.c.t.s.a.AuthenticatorExceptionHandler] [I: ] [U: ] [S: ] [T: https-jsse-nio-443-exec-4] [ The requested scope(s) must be blank or a subset of the provided scopes. ]
my sso-settings.json:
"BasicSettings": {
"clientBaseUrl": "https://ecsc00a00f1d.epam.com:443/Thingworx",
"idpMetadataFilePath": "/ThingworxPlatform/ssoSecurityConfig/sso-idp-metadata.xml",
"metadataEntityId": "https://ecsc00a00f1d.epam.com/Thingworx",
"metadataEntityBaseUrl": "https://ecsc00a00f1d.epam.com/Thingworx",
"webSSOProfileConsumerResponseSkew": 300,
"webSSOProfileConsumerReleaseDOM": true,
"webSSOProfileResponseSkew": 300,
"samlAssertionMaxAuthenticationAge": 7200,
"samlAssertionUserNameAttributeName": "uid"
"AccessTokenPersistenceSettings": {
"dbType": "postgres",
"driverClassName": "org.postgresql.Driver",
"url": "jdbc:postgresql://localhost:5432/thingworx",
"username": "twadmin",
"password": "pass",
"encryptTokenInDatabase": "false"
"KeyManagerSettings": {
"keyStoreFilePath": "/ThingworxPlatform/ssoSecurityConfig/keystore.jks",
"keyStoreStorePass": "pass",
"keyStoreKey": "tomcat8.5",
"keyStoreKeyPass": "pass"
"AuthorizationServersSettings": {
"PingFed1": {
"clientId": "twx_oauth_conn",
"clientSecret": "secret",
"authorizeUri": "https://ecsc00a00f1e.epam.com:9031/as/authorization.oauth2",
"tokenUri": "https://ecsc00a00f1e.epam.com:9031/as/token.oauth2",
"clientAuthScheme": "form"
Tags (2)
2 REPLIES 2
Re: SSO doesn't work with Pingfederate/Thingworx
Hi Iryna,
Seems like the SCOPE is not defined in correct way. We need to mention the same SCOPE in PingFederate and in Thingworx.
I'll suggest you to create a case with Support Services. A case can be logged with TS here
BR,
Harsh Selarka
Any success on this, I am also facing the same issue
Security log is saying:
2018-02-09 14:15:13.865+0000 [L: DEBUG] [O: o.s.s.w.c.SecurityContextPersistenceFilter] [I: ] [U: ] [S: ] [T: http-nio-8443-exec-1] SecurityContextHolder now cleared, as request processing completed
2018-02-09 14:15:13.868+0000 [L: ERROR] [O: S.c.t.s.a.s.ThingworxSSOAuthenticator] [I: ] [U: ] [S: ] [T: http-nio-8443-exec-1] [ Failed to utilize the SSO component for authentication ][ Error requesting access token. ][ 401 Unauthorized ]
2018-02-09 14:15:13.868+0000 [L: DEBUG] [O: S.c.t.s.a.s.ThingworxSSOAuthenticator] [I: ] [U: ] [S: ] [T: http-nio-8443-exec-1] authentication status: [false]
2018-02-09 14:15:13.868+0000 [L: ERROR] [O: S.c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-8443-exec-1] Could not handle request
2018-02-09 14:15:13.875+0000 [L: ERROR] [O: S.c.t.s.a.AuthenticatorExceptionHandler] [I: ] [U: ] [S: ] [T: http-nio-8443-exec-1] errorMessage: [Unauthorized], statusCode: [401]
2018-02-09 14:15:13.875+0000 [L: DEBUG] [O: S.c.t.s.a.AuthenticatorExceptionHandler] [I: ] [U: ] [S: ] [T: http-nio-8443-exec-1] ssoException exists: [true], recoverable: [false]
2018-02-09 14:15:13.875+0000 [L: ERROR] [O: S.c.t.s.a.AuthenticatorExceptionHandler] [I: ] [U: ] [S: ] [T: http-nio-8443-exec-1] [ Error requesting access token. ][ 401 Unauthorized ]
