We will host a live Expert Session: "Windchill & Thingworx Navigate Authentication" on November 10th at 10:30 AM EST.
Please find below the description of the expert session and the registration link .
Expert Session: Windchill & Thingworx Navigate Authentication
Date and Time: Tuesday, November 10th, 2020 10:30 am EST
Duration: 1 hour
Host: Arshad Imam, PLM Product Technology Lead
Description:
This in Expert Session will take you through a step-by-step approach for configuring authentication between Windchill and Navigate with SSL. Plus, you can take advantage of a unique opportunity to ask questions in a live Q&A following the presentation.
Existing Recorded sessions can be found on support portal using the keyword ‘Expert Sessions’.
You can also suggest topics for upcoming sessions using this small form.
Here are some recorded sessions that might be of your interest. You can find recordings for the full library of webinars using the keyword ‘Expert Sessions’ in PTC support portal search
Navigate 9.0 – What’s New? This session is the intro of a series that will cover new capabilities of the recent Navigate 9 release and the value that each can bring to your implementation. Then we will have further sessions covering the details of some of them |
Top 5 items to check for Thingworx Performance Troubleshooting How to troubleshoot performance issues in a Thingworx Environment? Here we cover the top 5 investigation steps that will help you understand the source of your environment issues and allow better communication with PTC Technical Support |
Thingworx 9.0 Component Based App Development Following the series of new capabilities released with Navigate 9.0, this session will focus in the details of Navigate Component Based app development and how to leverage this to your use cases |
Thingworx Navigate 3D Viewer Following the series of new capabilities released with Navigate 9.0, this session focus in the details of Navigate 3D Viewer leverage this to your use cases |
Hi All
Our expert session: Navigate - SSL & Windchill Authentication is tomorrow!!! Click the link below to register and remember to talk about it to colleagues that might benefit from its content:
https://www.ptc.com/en/resources/plm/webcast/windchill-and-navigate-authentication
See you there!
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
