Hi all
When installing TWX Navigate, the documents call for a patch to Windchill to support 'Contribute tasks'.
Thanks!
Rick
PS we have Windchill v11.0 M030 CPS12, Navigate 8.5.3
Hi Rick,
The answers to your queries :
1. Windchill Extension Patch is mandatory to be installed on Windchill server prior to Windchill 11.2 F000 CPS02. Starting from Windchill 11.2 F000 CPS02 extension patch is installed out of the box.
2. Yes patch is necessary.
3. Patches cannot be uninstalled. Only a full backup (Application and Database) and recovery strategy can ensure to roll back the system into a consistent pre-patched state
See PTC Windchill Backup and Recovery Planning - Technical Brief for more information.
4. Without patching on Windchill, Navigate will not be able to communicate and fetch data from Windchill.
5. The required PTC Windchill patch adds several web service endpoints that allow ThingWorx to interact with Windchill. Each patch includes instructions specific to the release. To install the patch, unzip the file and use the instructions found in the Readme file included with the patch.
6. Windchill 11.0 M030 CPS12 does not include Windchill Extension Patch.
Thank you
Arshad
Hi Rick,
Thank you
Arshad
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
