I have a Windchill ODATA End-point that streams(edm.stream) the representation of a document. Is there a code snippet to consume the stream from odata response.
I am not aware of an OOTB code snippet to consume the stream from the OData response.
Hi @Swamy_Senthil.
If you feel the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question. If you still have questions, please let us know.
--Sharon
Hi @Swamy_Senthil.
I have marked the Accepted Solution for your post. If you disagree that it is the solution, please provide further information and I will remove it.
--Sharon
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
