pingFederate Installation for SSO
Regular Member
pingFederate installation and licence file deployment  is same or different.
https://support.ptc.com/WCMS/files/172779/en/PTC_Single_Sign_on_Architecture_and_Configuration_Overv...
The attached document describes the Installing pingfederate, in which procedure for installation is not available but steps for deployment of licence file is available.
Can  anyone please help me out in installing the pingFederate..?
Madhu
Tags (1)
Re: pingFederate Installation for SSO
This is an area where the documentation is truly horrific.  If you try calling support they'll simply say that the documentation is still being updated.  Good luck getting this to work right now, until someone from PTC publishes a step-by0-step write up on how to get this working in both SSL/non-SSL environments.
Hi, Installation of PingFederate is nothing much, its just running the 'run.bat' file, deploying the license and creating a admin username and password
