PTC University, Viewing lessons on iPad?
ptc-4864603
Curious if there are plans to improve viewing tutorials/lessons on an iPad? Or is there some kind of trick to it?
Thank you.
1 ACCEPTED SOLUTION
Ryan,
Many of the tutorials on Learning Exchange for newer versions of PTC software will work on an iPad. Older tutorials were created in Flash which is not supported on the iOS. We have started creating tutorials and full eLearning courses in a format that is supported in multiple browsers and operating systems.
Best regards,
Kim Springston
Ryan,
Best regards,
Kim Springston
Thank you, I guess since I am using WF5 and viewing those maybe that's why I'm experiencing issues.
Are you able to scroll in the Procedure area of the window in these new versions? I noticed that I can view the videos and scroll in the Course Map area, but not in the content pane.
Is there a setting on my iPad I'm missing?
Thank you.
Edit: I just realized that I can copy all the content that is in the scroll disabled area and paste it into Evernote, guess that's a work around. Looking around for solutions it seems like an easy fix in the html header for that pane. I'm sure it sounds easy to do, but not to implement. Thanks again.
