Thermal analysis simulation w/ regards to gravity
SOLVED
Guest
Hi everyone, I was wondering someone could help me out? I'm looking for a tutorial on how to perform thermal analysis with regards to gravity. Also known as thermogravimetry. I use Creo 4.0, by the way.
Re: Thermal analysis simulation w/ regards to gravity
I don't believe its possible with Creo Simulate since the application has no multi physics capabilities or CFD built in functionalities. The analysis you are looking to perform would involve loss of substance do to heating (like evaporation of water out of a sponge or lubricant seeping out of a material do to the material being heated.
Don Anderson
Don Anderson
Ahh thanks for the clarification, Dan.
I hate to ask again, but is there really no simulation that could recreate what this tool does irl? https://www.linseis.com/en/our-products/thermogravimetry/
I just want to make sure.
Correct, not able to simulate this in creo simulate today.
You would have to go to a high end multiphyics software package.
Don
