i am a beginner, i want to work with smaller dimensions but when I enter dimensions like 2in. , the 2in. line appears micro whereas i have seen tutorial videos in which the display automatically zooms in when smaller lengths are entered. i am using CREO 3.0 M020 educational edition.
Hi, check you configuration option (set to YES) - sketcher_refit_after_dim_modify
