Suppose I have purchased Host option license of vuforia chalk which comes with bundle of 5 license.
My question is, Can I change the hosts frequently through admin centre?.
This is the question from one of the customers.
One more question can we share code via Registered (Mobile)user to Non-Registered (Mobile) user in user based license of vuforia chalk which comes with bundle of 50 users?
Suraj Patil
hi @Suraj_Patil
Admins can assign host privileges in the Admin Center as needed. This can be done by enabling or disabling the host checkbox on the user. More info can be found in the Help Center.
A host user can share the connect code with any other user to initiate a session. Joining a session does not require a chalk account. See here for all the different ways to use connect codes.
hi @Suraj_Patil
