Live AR annotations in joined session as a guest
aletenti
I was making some tests on the app.
In particular, I created a new session using a registered user.
Using another smartphone without logging into Chalk I simply joined the created session as guest.
I have noticed this scenario:
- if the host user shared the camera, it's possible to draw live annotations
- if the guest user shared the camera, it's NOT possible to draw live annotations, even if the guest user has a supported ARCore smartphone with AR sensors.
Is it an issue or it's a limitation ?
PG_10144204
(To:aletenti)
Hi @aletenti ,
Basic user
  • Starts sessions with contacts or joins hosted sessions
  • Uses Chalk features and functionality including drawing Chalk Marks (annotations), viewing and saving session summaries, using low bandwidth mode, etc.
For more in-depth details, please refer to the user roles and permissions--> https://www.ptc.com/en/success-paths/get-started-with-vuforia-chalk/setup/invite-users
