Last week I applied for the 30 day Evaluation of Chalk. However, the application has been rejected. I would like to be approved by you, what should I do?
I already use a personal edition, is it affected?
This problem was solved by having PTC Japan cooperate.
The cause is as follows.
Fallon, Duffy <dfallon@ptc.com> wrote 2018/09/18 :
I just heard back from the team on our side – it looks like the rejection happened because as a partner, you needed to include a (P) in front of the business name. I just want to confirm that you’re seeking to sign up for a partner account and I can go ahead and get everything setup.
@Tetsu Could you please share the login ID been used to signup for Chalk ? We can check internally to get feedback on the request status.
-Durgesh
Thank you for your reply.
login ID : takahashi.tetsuto@canon-its.co.jp
Please check it.
Hi @danhitomi,thank you for your reply.
Should I wait for a while now? Or will you apply for the 30 day Evaluation of chalk again?
Hi @Tetsu - you should not need to wait.
I'll send you an email and we can talk you through next steps.
Hi @Tetsu.
If your issue has been resolved, please post the solution here and mark it as the Accepted Solution. This will benefit others who may have the same issue.
--Sharon
