My application for the 30 day Evaluation of Chalk was not approved
Tetsu
Last week I applied for the 30 day Evaluation of Chalk. However, the application has been rejected. I would like to be approved by you, what should I do?
I already use a personal edition, is it affected?
Tetsu
(To:slangley)
This problem was solved by having PTC Japan cooperate.
The cause is as follows.
Fallon, Duffy <dfallon@ptc.com> wrote  2018/09/18 :
I just heard back from the team on our side   it looks like the rejection happened because as a partner, you needed to include a (P) in front of the business name.  I just want to confirm that youre seeking to sign up for a partner account and I can go ahead and get everything setup.
7 REPLIES 7
dupatel
(To:Tetsu)
@Tetsu Could you please share the login ID been used to signup for Chalk ? We can check internally to get feedback on the request status.
-Durgesh
Tetsu
(To:dupatel)
Thank you for your reply.
login ID : takahashi.tetsuto@canon-its.co.jp
Please check it.
danhitomi
11-Garnet
(To:Tetsu)
Hi @Tetsu and @dupatel -- apologies for the delayed response, I had intended on responding yesterday.
Let me check-in on this as I'm curious why you were not approved and also get you setup for an evaluation.
I'll cc: you on an email that I'll be sending out shortly.
Dan Hitomi
Product
Tetsu
(To:danhitomi)
Hi @danhitomi,thank you for your reply.
Should I wait for a while now? Or will you apply for the 30 day Evaluation of chalk again?
danhitomi
11-Garnet
(To:Tetsu)
Hi @Tetsu - you should not need to wait.
I'll send you an email and we can talk you through next steps.
Dan Hitomi
Product
slangley
(To:danhitomi)
Hi @Tetsu.
If your issue has been resolved, please post the solution here and mark it as the Accepted Solution.  This will benefit others who may have the same issue.
--Sharon
Tetsu
(To:slangley)
