The upcoming release of Vuforia Chalk will include changes to the URLs below:
Chalk for Desktop will move from connect.vuforia.com to vuforiachalk.com
The Chalk Admin Center will move from admin.vuforiachalk.com to vuforiachalk.com/admin
URLs for authentication and Chalk cloud services will not be changed
Check your firewall by visiting vuforiachalk.com from the browser you use to access Chalk for Desktop and the Chalk Admin Center.
If the page does not load with a green success symbol, check that your firewall settings allow traffic to vuforiachalk.com without the “admin.” prefix. Your IT department may need to update enterprise firewall settings in your network.
Network configuration guidance is also available in the Chalk Help Center.
