Precise acessar ou Vuforia Chalk através do Host / Código através do connect.vuforia.com, mas usando os telefones Samsung A10 e Motorola G7
Você sabe que eu posso fazer isso?
It sounds like you'd like to use Chalk for Desktop (connect.vuforia.com) paired with the Samsung A10 or Motorola G7. Is this correct? Currently Chalk is not supported on either device, so annotations may not work with this device combination. When using Chalk for Desktop it is important that the device sharing their view is supported so that annotations can be used during the session. See our Live Annotations Help Center topic for more information on this.
Yes, you are correct about my question.
Unfortunately my customer can't use that devices.
Thanks so much
