Does changing a capture title result in a new QR code being generated?
Nicole_Holm
6-Contributor
Hello -- When we first adopted VEC, we were told that changing a capture title after publishing would result in a new QR code being generated for that capture. Recently, we have needed to change a few of our capture titles, but the original QR code still scans and loads the capture with the new capture name. Is a new QR code generated when a capture title changes?
We have more capture titles that require changes, but QR codes for these captures have been shared with our customers. I want to avoid changing a capture title if it would mean that the original QR code would no longer work.
1 ACCEPTED SOLUTION
hi @Nicole_Holm
The procedure title isn't included in the QR code so updating the procedure title will not impact the existing QR code. The new title will be displayed once the procedure is republished.
1 REPLY 1
hi @Nicole_Holm
Topics available:
AR/VR for Data Optimization AR/VR for Security and Control AR/VR for Inspection
