Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
What's New in Vuforia Expert Capture and Vuforia Instruct 3.4.0
Vuforia Insights
Updates and Improvements to Viewer Insights Page
The VIEWER INSIGHTS table on the Viewer Insights tab now displays procedure sessions that are currently in progress and any that were deleted by the end user
A new STEP LAST VISITED column displays a timestamp to indicate when the user last visited a step
The VIEWER INSIGHTS table now displays a LAST MODIFIED column that displays the date and time that the session was last modified. Previously, there was only a COMPLETED column which displayed the date that a session was completed
New filters were added to the top of the VIEWER INSIGHTS table
The following columns in the VIEWER INSIGHTS table have been updated
PROCEDURE STATUS will become PROCEDURE PASS/FAIL
DESCRIPTION will become STEP DESCRIPTION
MEDIA will become STEP MEDIA
Vuforia Editor
Mandatory image feedback for Step Check steps
Authors can now require image feedback for steps with Step Check enabled
Vuforia Vantage
The text and image feedback button has moved to the top-right of the step card
Vuforia Vantage is no longer supported on iOS devices running iOS 14
