content takes time to load and not fully show inside the frames
MaF
8-Gravel
8-Gravel
Vuforia Expert Capture
After creating the steps in the editor with all the resources that should be part of the experience below are the challenges I am experiencing:
1. The captured content/resources takes time to load even when I am on fiber (my location is South Africa - can the reason be because of data centres being too far and therefore it takes a while to fetch the content/resources?)
2.Content that was included during the steps creation on the editor do not fully show inside the frames when the experience is consumed - is there maybe a recommended size for images, I have even tried to use the optimization setting within the editor?
tmccombie
(To:MaF)
Can you share some more information about the second issue you are facing? What devices are you using to view the published procedure?
MaF
8-Gravel
8-Gravel
(To:tmccombie)
I am using Hololens 2.
