Can we select an entire plate as part for step check instead of a single point?
AP_10483126
11-Garnet
I am trying to use vuforia step check and mainly trying to create a line using paper pieces and if the line is intact i should get a green tick and if the line is distored i need to get a red tick. (Attached good and bad image). when we try to use the point marker it will be indicating the specific point. how can we do this for the entire plate as shown in images?
0 REPLIES 0
