Hi guys,
I am building a demo. I wanted to see if I can capture the instructions for each step through the audio when I record each step.
Is there such a functionality in Expert Capture yet? Or do I have to manually type the instructions for each step in the editor to export it to the Word document?
There is currently no voice to text feature for the step instructions. You would need to write out the required instructions if you are looking to export to a word document.
