Description of a folder - How to modify it?
pjahn
When you create a folder in Vuforia Editor, you can add a description to it. This works without any problems. Where can I modify this description after creating the folder?
I am grateful for any advice.
Feature suggestion: The content of the description should also be taken into account in the search and should be able to be displayed as a column.
Thank you.
azupfer
(To:pjahn)
Hi @pjahn. Currently, editing the description of a folder is not supported, but it is on our roadmap. And, thank you for the feature suggestion; I will pass it along to development.
Thank you,
Amanda
azupfer
(To:pjahn)
Thank you,
Amanda
pjahn
(To:azupfer)
Just to be sure. There are two suggestions for improvement:
- The description of folders should be modifiable.
- The content of the description of folders should be included in the search function.
