Image Dimension for Procedure in Vuforia Expert Capture
GO_9986537
What is the min and max dimension size being imported into Expert Capture to prevent it from being cut off in the step of the procedure or title slide? @tmccombie
@GO_9986537 Are you experiencing image cut-off issues within Vantage on mobile or View on HoloLens/Realwear devices? Is it possible to share a screenshot of the issue?
GO_9986537
(To:tmccombie)
@tmccombie Thanks its already been attended in a PTC case #16338637
Hello, could you please share the resolution? Thanks
Case 16338637 is not accessible for us. We can not see a solution either. It would be nice if you would copy the answer from the case to this thread.
Thank you.
GO_9986537
(To:pjahn)
Well we tested the shared images in my Vuforia Editor and I am not able to reproduce the issue, after it the end customer didn't share the recording and after several tries to follow up we didn't receive an answer so the ticket/case was closed without solution.
