What is the min and max dimension size being imported into Expert Capture to prevent it from being cut off in the step of the procedure or title slide? @tmccombie
@GO_9986537 Are you experiencing image cut-off issues within Vantage on mobile or View on HoloLens/Realwear devices? Is it possible to share a screenshot of the issue?
Hello, could you please share the resolution? Thanks
Case 16338637 is not accessible for us. We can not see a solution either. It would be nice if you would copy the answer from the case to this thread.
Thank you.
Well we tested the shared images in my Vuforia Editor and I am not able to reproduce the issue, after it the end customer didn't share the recording and after several tries to follow up we didn't receive an answer so the ticket/case was closed without solution.
