If a text is added to an image in Vuforia Editor, the size of the text in the input field can be set to a maximum value of 100. A value of 120, for example, cannot be entered. However, if you scale the inserted text with the mouse pointer, the text can also be scaled to a value above 100. It makes no sense that you cannot enter a value above 100 in the input field. It would be good if this could be changed and you could also enter a value above 100 in the text field.
I have added a screen recording to explain the problem more clearly.
