Unshare a procedure
pjahn
Unshare a procedure
I shared a procedure to two different users in VEC. Now I would like to unshare it again but I can not remove those two users from the sharing dialog. There is no remove option available in the user interface.
I can decide between "Read only" and "Can edit". How to remove a user in the "Share" dialog?
tmccombie
(To:pjahn)
You should have an 'x' next to their privileges that will 'unshare' the procedure. From your screen shot it looks like you'll need to scroll to the right see the x.
tmccombie
(To:pjahn)
Yes. Scrolling to the right is the solution.
@tmccombie  Thank you.
