Vuforia Expert Capture Editor - Unresponsive
Highlighted
Regular Member
I am running into a customer issue where they can log into their VEC Editor portal just fine but then the page is unresponsive. They cannot filter by public, shared, created by me etc.
They have encountered this sporadically but enough to bring it up.
Is there a troubleshooting method I can point them to? Is this a common issue?
3 REPLIES 3
Highlighted
Re: Vuforia Expert Capture Editor - Unresponsive
I haven't heard of or experienced this issue before. A good thing to check would be the browser console logs when this is happening. May be some sort of indication as to what is happening in there. Can you confirm what browser they are using?
Highlighted
They are using Chrome - I will check the console logs.
Highlighted
You can also try clearing the browser cache to see if that helps. What version of Chrome they are using?
Join an
AR Working Group!
Topics include:
AR/VR for Data Optimization, AR/VR for Security and Control, and AR/VR for Inspection.
