What's New in Vuforia Expert Capture 3.6.0
ytella
General:
  • Vuforia Instruct Features Now Included in Vuforia Expert Capture
    • Beginning with the May 2023 release, all features and capabilities that were available in Vuforia Instruct will be consolidated with Vuforia Expert Capture. The table below explains what, if any, changes to expect:
    • For more information about the product consolidation, see Vuforia Instruct and Vuforia Expert Capture Consolidation.
  • Step Check™ Official Release and Updates
    • Step Check is now officially available to all customers and is no longer in beta! Other updates to Step Check include:
      • The Step Check mode that has been set for the step is now displayed on the step card
      • A new menu is available for markers on a step with Step Check enabled which allows you to either remove Step Check and the point marker, or convert the Step Check and point marker to just a point marker.
    • For more information, see Step Check™
Vuforia Editor
  • New Organization Setting to Require Review and Approval Before Publish
    • A new organization setting allows administrators to control the number of approvers required before a procedure can be submitted for approval. This value can be set to require 0-20 approvers with 0 being the default.
      If one or more approvers are required, the PUBLISH tab of the procedure will be updated to reflect the number of required approvers, and the ability to start the approval process will be blocked until the required number of approvers have been added. If the value is set to 0, standard publishing and approval rules apply, and no minimum number of approvers will be enforced.
    • NOTE: This setting only affects release candidates created after the required number of approvers has been set. Release candidates that are pending when the number of approvers is set will not be impacted.
Vuforia Vantage
  • Bug Fixes and Minor Improvements
Insights:
  • Approval Reasons Now Displayed in Audit History Table
    • Approval reasons are now displayed in the AUDIT HISTORY table for Reviewed and Approved Release Candidate and Rejected Release Candidate audit events. Approval reasons will be displayed for newly created events in the Audit History table and the downloaded report; historic events will not be modified. Below are examples of the new formats:
      • Rejected Release Candidate - Subject Matter Expert Approval
      • Rejected Release Candidate - Subject Matter Expert Approval (Signed)
Settings
  • New Require Review and Approval on Procedure Publishing Setting
    • A new Require Review and Approval on Procedure Publishing setting is available from Product Settings. This setting allows organization administrators to set a minimum number of users that need to review and approve procedures before they can be published. For more information, see Require Review and Approval on Procedure Publishing.
  • New Product Update Tab (GMP Organizations Only)
    • A new Product Updates tab is available that allows organization administrators to decide when Product Update Bundles are released into a production environment. For more information, see Product Updates (GMP customers only).
Additional Information
0 REPLIES 0
