Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
What's New in Vuforia Expert Capture and Vuforia Instruct 2.10.0
Ability to move assets in bulk when in List View in Vuforia Editor
Improvements to part sets in Vuforia Editor (Vuforia Instruct only)
Duplicate a part set
Add a part to a part set
Remove a part from a part set
New color palette is available in Vuforia Vantage for mobile devices that allows you to select the color of augmentations on the object (Vuforia Instruct only)
Beginning in May of 2022, Vuforia Capture will no longer be supported on 1st generation HoloLens devices (Vuforia Expert Capture only)
