Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
What's New in Vuforia Expert Capture and Vuforia Instruct 3.0.0
A new Settings page is available to Administrators that gives them access to a Product Settings tab allowing them to manage product-specific settings that are unique to Vuforia Expert Capture and/or Vuforia Instruct
Major UI updates and improvements have been made to the Procedure Editor pane making procedure authoring more efficient and intuitive
