What's New in Vuforia Expert Capture and Vuforia Instruct 3.1.0
tmccombie
Vuforia Editor
  • More efficient Advanced Model Target training with training lengths varying between 20 minutes to 4 hours.
  • Step Check (Beta) is now available for Vuforia Instruct users, allowing them to use AI (artificial intelligence) to assist users in visually verifying if a step in a procedure has been performed correctly or not.
Vuforia Vantage
  • iOS 16 is now supported for Vuforia Vantage
  • You can now reset tracking in Vuforia Vantage on HoloLens 2 devices. Use the Reset Tracking button or the "Reset tracking" voice command to reset the tracking for Area Target locations.
Vuforia Insights
  • A new Audit History tab is available that displays a table of meaningful events throughout the lifecycle of a procedure. New events will be logged as users perform the following actions:
    • Create a procedure
    • Publish or unpublish a procedure
    • Create a new version of a procedure
    • Approve, reject, or cancel a release candidate
    • Archive or delete a procedure
Settings
  • A new setting is available to enable and disable the Step Check beta feature in Vuforia Editor. By default, this setting is enabled, and the following additional user interfaces will be displayed:
    • Pass/Fail with Step Check option in the feedback type drop-down of a step card
    • When Pass/Fail with Step Check is selected as the feedback type for a step, Step Check Dashboard will also be available from the step card
    • STEP CHECK tab in the procedure editor pane
    • Step Check section on the PUBLISH tab
      • Note: This setting is visible to all organizations but is only applicable to Vuforia Instruct
0 REPLIES 0
