will 3d guided Assembly step by step instructions possible in vuforia expert capture
thrinath
VladimirN
(To:thrinath)
thrinath
(To:VladimirN)
Hi Vladimir N Thank you for your replay.
As I checked in ptc portal( Augmented Reality Work Instructions | Vuforia | PTC) and the below image where it clearly given as 3D visual guides with step-by-step instructions. image.png
mwodarz_INNEO
(To:thrinath)
PTC show some use cases in a gallery: https://ar.gallery.video/
There you'll see AR guidance with Expert Capture and Vantage, but also 3D assembling instruction in AR, done with studio.
Hope this helps to distinguish the solutions.
(Presales) Senior Technical Consultant @ INNEO Solutions GmbH (Germany)
