Emeritus
Extracting the viewables and the seqnece steps information from a .pvz file for the usage in TWX
This post should provide more detailed steps additionally  to the posts ("How to extract the components with properties from a pvz file"[1.] and "How to use ThingView Widget from Navigate to display CAD Model/Viewables in custom mashup- Concept"[2])  This post should consider more detailed the steps for the extracting of viewables and also how to extract the sequence steps information from a .pvz / Creo Illustrate model for further usage in a Thingworx service.
Following steps:
1.) Extracting the data from the Creo View Model ( Created from Creo Illustrate via publish to pvz functionality)
As described in [1.] we required for the extraction of information a Creo View Toolkit.  A good choice will be the usage the Creo View  WebGL toolkit module.
A web toolkit program is called inside a html document ,where the javaScript Creo View WebGl Api is embedded. So, the most important logic could be called on the windows load function. The code below will initialize  the thingview library and  will open the pvz model file (value of variable CUR_MODELPATH in the code below  is set the complete model path):
window.onload = function() { ThingView.init("js/ptc/thingview", function() { // ThingView should only be initialised once per frame //---------------------------------- //send the modelname to server var xhr = new XMLHttpRequest(); xhr.open("POST", "RAY_LOG_FILE:", true); xhr.setRequestHeader("Content-Type", "application/json"); xhr.onreadystatechange = function() { if (xhr.readyState === 4 && xhr.status === 200) { var json = JSON.parse(xhr.responseText); } }; //set the json modelname object var JSON_BOM_MODEL_OBJ = new Object; MODELNAME = CUR_MODELPATH.substring(CUR_MODELPATH.lastIndexOf("/") + 1) JSON_BOM_MODEL_OBJ.name = "BOMMODELNAME"; JSON_BOM_MODEL_OBJ.value = MODELNAME; xhr.send(JSON.stringify(JSON_BOM_MODEL_OBJ)) console.warn("sent BOMMODELNAME=" + MODELNAME) //finish the sending of the model_name //---------------------------------- console.log("Creo View WebGL Viewer is now initialised"); session = ThingView.CreateSession("CreoViewWebGLDiv"); //refers to the CreoViewWebGLDiv -> a div area in the html fileSource // which contains the code var xhttp = new XMLHttpRequest(); MODELNAME = CUR_MODELPATH.substring(CUR_MODELPATH.lastIndexOf("/") + 1) xhttp.open("POST", "RAY_JSON_VIEWABLE:", true); xhttp.setRequestHeader("Content-Type", "application/json"); xhttp.onreadystatechange = function() { if (xhttp.readyState === 4 && xhttp.status === 200) { var json = JSON.parse(xhttp.responseText); } }; var js_obj = new Object; js_obj.name = "VIEWABLE"; js_obj.value = MODELNAME; var data = JSON.stringify(js_obj); xhttp.send(data); model = session.MakeModel(); ////==================LoadFromURL Callback model.LoadFromURLWithCallback(CUR_MODELPATH, true, true, false, function(success, isStructure, errorStack) { var illustrations = model.GetIllustrations(); for (var i = 0; i < illustrations.size(); i++) { console.log("Illistration name: " + illustrations.get(i).name); // seems illustrations.get(i).name == pviFile model.LoadIllustrationWithCallback(illustrations.get(i).name, function(success, pviFile, stepInfoVec) { if (success === true) { var hasAnimation = model.HasAnimation() var hasSequence = model.HasSequence() xhttp.open("POST", "RAY_JSON_VIEWABLE:", true); xhttp.setRequestHeader("Content-Type", "application/json"); xhttp.onreadystatechange = function() { if (xhttp.readyState === 4 && xhttp.status === 200) { var json = JSON.parse(xhttp.responseText); } }; var js_obj = new Object; js_obj.name = pviFile; js_obj.value = pviFile; js_obj.type = "viewable"; js_obj.hasSequence = hasSequence; js_obj.hasAnimation = hasAnimation; var data = JSON.stringify(js_obj); xhttp.send(data); for (var ii = 0; ii < stepInfoVec.size(); ++ii) { xhttp.open("POST", "RAY_JSON_VIEWABLE_STEP:", true); xhttp.setRequestHeader("Content-Type", "application/json"); xhttp.onreadystatechange = function() { if (xhttp.readyState === 4 && xhttp.status === 200) { var json = JSON.parse(xhttp.responseText); } }; var step_obj = new Object; console.log("step nr=" + ii); step_obj.viewablename = pviFile; step_obj.nr = ii; step_obj.name = stepInfoVec.get(ii).name; step_obj.description = stepInfoVec.get(ii).description; var data = JSON.stringify(step_obj); xhttp.send(data); //============================================= } } }) } ////============= setTimeout(function() { { xhttp.open("POST", "RAY_JSON_VIEWABLE:", true); xhttp.setRequestHeader("Content-Type", "application/json"); xhttp.onreadystatechange = function() { if (xhttp.readyState === 4 && xhttp.status === 200) { var json = JSON.parse(xhttp.responseText); } }; var js_obj = new Object; js_obj.name = "FINISHVIEWABLES"; var data = JSON.stringify(js_obj); xhttp.send(data); } }, 10000); }); ///model load from URL funciton ///////////// }); // ThingView.init( ) }; //window onload function
The program will generate 2 different json files and will send them to the http server.
When the Creo View WegGl program is started (load  the html file from the http server)  - on the server side - in the node.js console  we can see the printing of the received data - example on the picture below:
The Creo View WebGl program will create on the server side  2 json files (this requires also handling of the received  data on the server side as allready mention in the post [1.]  )
For the data extraction I used in this example the PTC demo file (provided with the installation of Creo View Toolkit) : worldcar-brake-multi-figure.pvz,
worldcar-brake-multi-figure.pvz-viewableSteplist.json
[{"viewablename":"Sequence","nr":0,"name":"Sequence","description":""},
{"viewablename":"Sequence","nr":1,"name":"Step 1","description":"Remove spring clips"},
{"viewablename":"Sequence","nr":2,"name":"Step 2","description":"Release 4 bolts"},
{"viewablename":"Sequence","nr":3,"name":"Step 3","description":"Pull apart the calipers"}]
worldcar-brake-multi-figure.pvz-viewablelist.json
[{"name":"Figure 1","value":"Figure 1","type":"viewable","hasSequence":false,"hasAnimation":false},
{"name":"Sequence","value":"Sequence","type":"viewable","hasSequence":true,"hasAnimation":false},
{"name":"Parts List","value":"Parts List","type":"viewable","hasSequence":false,"hasAnimation":false},
{"name":"Sectioning","value":"Sectioning","type":"viewable","hasSequence":false,"hasAnimation":false},
{"name":"Translation","value":"Translation","type":"viewable","hasSequence":false,"hasAnimation":false},
{"name":"Animation","value":"Animation","type":"viewable","hasSequence":false,"hasAnimation":true}]
2.) Definition of a service in Thingworx for the returning of the Sequence Step List (see also "Service for creating of Bom - and Viewable Lists from json files"  [3]  )
Here the first Step is to define a general service which will will convert the JSON file from a file repository to an InfoTable using particular dataShape.  The json file will be taken from a  repository:
var params = {
	path: the_json_path /* STRING */
var Content = Things[the_Repository_Name].LoadJSON(params);
var params1 = {
infoTableName: undefined /* STRING */,
dataShapeName: the_dataShape_name /* DATASHAPENAME */
// result: INFOTABLE
var jsonTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params1);
var result = DataShapes.ThingviewBomData.CreateValues();
for(i in Content.array){
 jsonTable.AddRow(Content.array[i]);
result = jsonTable; //returns the InfoTable
The service has 3 Input parameters : the_json_path, the_dataShape_name and the_Repository_Name (all are String type)
This service could be called for any filerepository, containing any json files(it is not file specific) . Via the dataShape name we will specify the filed definitions.  We need to do this  for each specific json file. In this case we have to  create first manually a DataShape which is compatible to the Json Object.  For example when we start the service RayJsonToInfoTable:
And the dataShape what we need to define for  this particular example:
For the achieving  of the final goal -> the creation of the  Sequence Step List. We need to create a  another service where we can specify the arguments for DataShape and  repository name. Example:
So the input argumets are:
I.) the path to the json file
and
II.) the name of the sequence for which we want to see the steps.
I am not sure if we can omit the step , where we create a  dataShape for specific json - so some kind of  dynamic dataShape generation - because in such case  we need only to specify the json file without manual editing opreration.
