Hey,
Can i connect vuforia stuio Trial version with local Thingworx (Licensed) ?
If yes could you please share some docs.
Thank you
@RY_9064119 With Trial Studio there is a limitation to use associated ThingWorx instance provisioned with the trial account. You might not be able to configure your local licensed ThingWorx with Studio Trial.
