I created an experience in which I want to show sequence location with Blinking 3D Image (Arrow).
@-webkit-keyframes blinker {
from {opacity: 1.0;}
to {opacity: 0.0;}
.blink {
text-decoration: blink;
-webkit-animation-name: blinker;
-webkit-animation-duration: 0.6s;
-webkit-animation-iteration-count:infinite;
-webkit-animation-timing-function:ease-in-out;
-webkit-animation-direction: alternate;
I used above css on 3D lable but it's not working.
Can someone help me with this or give any better solution.
You can use $interval function as follow:
$scope.blink= function(){
interval= $interval( function(){
$scope.app.view.Home.wdg["3DImage-4"]["visible"] = !$scope.app.view.Home.wdg["3DImage-4"]["visible"];
500); // interval duration .5 second
Consider cancelling the interval whenever you're done with it by:
$interval.cancel(interval);
