Hey all,
I have rebuild the Blue Pump Demo for the Hololens and with gestures and voice commands.
Everythings is working fine instead of the "live" data coming from ThingWorx.
I am using a Thing that is generating random data on his properties. I use the external data panel in Studio to bind the properties to 3D gauges and 3D Labels in the Hololens experience. In the Composer and in the experience preview i see that data is changing but on the Hololens I see no data.
Has anybody the same issue?
Seb
Did you allow anonymous activity on the "Thing" for "Property Read," "Service Execute," and "Event Subscribe"? If you created a new Thing, these permissions need to be enabled for that Thing.
Thanks Milan, that was the case. I missed that the hololens experiences are always public.
Sebastian would you share that thingmark? :-))
Hey Martin,
sure here is the ThingMark (530:99), but I am still working on the experience to bring in more features.
I have implemented one gestures and three voice commands so far:
Hello Sebastian
would you be kind to share step by step creating voice commands for hololens?
Kind regards
Daniel
Hej Daniel,
did you check the help of studio?
It's pretty straight forward to create voice commands -> right side of studio / Data pane.
Voice alias is what you would say to trigger the command.
voice response is what "view" will say after it recognized the command. (advanced: this can also be the step instructions - or whatever with some JS)
https://help.vuforia.io/studio/#page/ThingWorx_Studio_Help_Center%2FEyewearBestPractices.html
