3D Widgets showing no data from TWX
sbergner
7-Bedrock
Hey all,
I have rebuild the Blue Pump Demo for the Hololens and with gestures and voice commands.
Everythings is working fine instead of the "live" data coming from ThingWorx.
I am using a Thing that is generating random data on his properties. I use the external data panel in Studio to bind the properties to 3D gauges and 3D Labels in the Hololens experience. In the Composer and in the experience preview i see that data is changing but on the Hololens I see no data.
Has anybody the same issue?
Seb
mthakker
(To:sbergner)
Did you allow anonymous activity on the "Thing" for "Property Read," "Service Execute," and "Event Subscribe"?  If you created a new Thing, these permissions need to be enabled for that Thing.
6 REPLIES 6
mthakker
(To:sbergner)
Thanks Milan, that was the case. I missed that the hololens experiences are always public.
mwassmann
(To:sbergner)
Sebastian would you share that thingmark? :-))
Hey Martin,
sure here is the ThingMark (530:99), but I am still working on the experience to bring in more features.
I have implemented one gestures and three voice commands so far:
  • "Play Sequence" / doubletap - starts disassembly sequence
  • "Show Data" - shows simulated sensor data
  • "Remove Data" - hides sensor data
drapo
(To:sbergner)
Hello Sebastian
would you be kind to share step by step creating voice commands for hololens?
Kind regards
Daniel
mwassmann
(To:drapo)
Hej Daniel,
did you check the help of studio?
It's pretty straight forward to create voice commands -> right side of studio / Data pane.
Voice alias is what you would say to trigger the command.
voice response is what "view" will say after it recognized the command. (advanced: this can also be the step instructions - or whatever with some JS)
https://help.vuforia.io/studio/#page/ThingWorx_Studio_Help_Center%2FEyewearBestPractices.html
