Click the button once to visible the 3D image and click again to hide.
How can I implement it with Vufortia?
Hi @ccss1 ,
with javaScript using a global variable this is easy to implement.
The variable should save the status of the current display.
Another option is to check simple the visibiltiy of the 3D Image
Example it could be something like :
$scope.MybuttonClickEvent = function()
if ($scope.view.wdg['3DImage-1']['visible'] == true)
$scope.view.wdg['3DImage-1']['visible'] = false;
else
$scope.view.wdg['3DImage-1']['visible'] = true;
Hi @ccss1 ,
else
