Hi Everyone,
I have made a Vuforia Studio Experience in which it captures a screenshot through tml3drenderer and uploads it to thingworx repository.
The data does transfers from vuforia studio to thingworx when I preview it in laptop through browser, but it does not gets transferred when I preview the same experience through my ipad.
Can anyone please help me out asap.
Thanks in Advance.
Aditya Gupta
This issue has been solved & it was related to timeout function.
As multiple function was called on a single click I assigned a time delay for each of the function & at present it's working.
I'll post if further any issue arises.
Best Regards,
Aditya Gupta
Similar discussion - "Experience works on vuforia studio(PC) but not properly on view App": https://community.ptc.com/t5/Vuforia-Studio/Experience-works-on-vuforia-studio-PC-but-not-properly-on-view/td-p/951469
Since in the above link they have suggested to use global parameters, can you please help me in
how to increment the global parameters just like we do for any variable
eg. If I want to increment the value of variable i I will simply write i++;
but how to do the above, incase of global parameters.
Best Regards,
Aditya Gupta
