After add TML text widget in Vuforia Studio 9.2.3.5193 , project can not be previewed.
loyang
Uncaught Error: [$injector:modulerr] http://errors.angularjs.org/1.5.3/$injector/modulerr?
the module fails to load
loyang
(To:loyang)
The cause of the problem has been found. It is related to the loaded user extension widgets (Studio 3d chart widgets  https://github.com/ptc-iot-sharing/3DChartWidgetStudio ). After deleting the extended widgets , the problem is solved.
4 REPLIES 4
VladimirN
24-Ruby II
(To:loyang)
Here is a solution from another thread: "Could try removing the node_modules symlink under Documents\VuforiaStudio\Projects. That link will get re-created the next time you open Studio".
Link: https://community.ptc.com/t5/Vuforia-Studio/What-s-New-in-Vuforia-Studio-8-3-1/m-p/558901#M3592
I have tried the method of removing the node_modules symlink under Documents\VuforiaStudio\Projects, and it can't solve this problem.
 it maybe related to the modules being moved to the @ptc directory.
loyang
(To:loyang)
VladimirN
24-Ruby II
(To:loyang)
Glad you solved your problem. Please mark your answer as "Accept as Solution".
