Hi there!
I'm facing an error when trying to publish a sample project.
I've successfully downloaded and installed the Vuforia Studio software, logged into my account(Username: hayk.nazaryan@ni.com) and created a sample project. I configured the Default Experience Service URL and have admin privileges, but when I hit Publish, after preparing and uploading the content, publishing fails with an error message "Permission denied uploading". When I check the logs, there is a message "Insufficient permissions to access resource","errorCode":403,"error".
I reinstalled the software several times, deleted the "builder-settings" file at C:\Users\Documents\VuforiaStudio and the issue still remains. Also what I've noticed in this file is "https://16e3e79bf17b30d7.studio-trial.vuforia.io" changed to "https://ni-dev.es.thingworx.com" with a true flag for "acceptedLicense".
Please provide some guidance to resolve the problem.
Thank you,
Hayk
Hello Nazaryan,
I have alook to this article :
https://www.ptc.com/en/support/article/CS268110
Best regards,
Samuel
I have some questions :
Best regards,
Samuel
Hi Samuel,
Thanks for your prompt reply!
Let me know in case any additional information is needed.
Hayk
Hello Nazaryan,
Best regards,
Samuel
Hey Samuel,
Thanks for the steps provided! The issue is solved.
Just wanted to confirm one thing. Is that a necessity to create a group of users to grant the needed permissions or it's enough to create an individual user that the administrator creates?
Thanks and regards,
Hayk Nazaryan
Hello Nazaryan,
The best is to create a group if you have many developers who are working in parallal in Vuforia Studio.
If you have only developer user, an user account is enough.
Best regards,
Samuel
