We are aware of an issue causing intermittent login problems for some users following a recent update. Learn More
Animations pvi included in pvz (created with creo illustrate 3) saw in hololens aren't equal to the preview or the mobile version. Why? For example: when I rotate a object composed by various parts, in preview the rotation is correct but when I see it in hololens, each part isn't syncronized.
I have seen the same behavior,
For example, if you create a movement in illustrate you can set a rotation axis, and rotate warts around that axis.
In the Hololens this moves each part to the new location.
Did not find a reason why.
Hololens is still on the old renderer and thus doesnt support all the functionalies and movements.
Take into account Hololens = Creo Illustrate <=4.0 only.
I used Creo Illustrate 3
yes, thats good. Otherwise you wouldn't be able to run any sequence .
Still some of the movements/ more complex movements are not supported due to the fact that Hololens is still running on the old renderer - and not on thingview renderer (preview, all mobile devices, all windows devices).
