Augmented Reality (Vuforia Studio)
PI_10616642
I want to add the Multiple Choice Question (MCQ) in the Vuforia Experience (with Vuforia Studio). How I can do that ?
Hi @PI_10616642 ,
there are different ways to implement muti choice . Depending on the data, how long should be the info text etc.
- So for example  here 2 possible option
  1. you can use a popup with list elements - select widget:2023-03-16_11-52-59.jpg
  2. or you can use 2d repeater Widget to implement some multi choice :2023-03-16_11-59-13.jpg
but there also other widget could be used. So it depends on the design of UI what you want to implement
but generally there is no a standard way to do this. Means every user could implement this what is the user understanding for multichoice , depending on the particular requirements
5 REPLIES 5
Hi @PI_10616642 ,
Thank You @RolandRaytchev for the solution. I will try to implement in my experience
HIi @RolandRaytchev if possible can you please elaborate popup with list elements method.
thanks for the feedback! Ok if this could be interesting for your I will provide the sample project where is the   picture (first picture) please, check it and if you have some question about the functionality or idea how to extend ( i mean from UI design) then , please , let me know. Thanks
Thank You @RolandRaytchev for the help.
